Extensions
Problems building extensions in VS Code: "Unable to load schema ..."
AntonioSousa
Today, I'm trying to build an extension I had to test. Can't manage to do it through the GUI, as it says:
  • Unable to load schema from '/home/administrator/.config/Code/User/globalStorage/dynatraceplatformextensions.dynatrace-extensions/1.285.0/extension.schema.json': No content.
It really depends, I have a lot of different ones, both from old/new schemas:
In the process, I have seen that the schemas are really downloaded with HTTP, but then it redirects:
Even creating an extension from scratch yields the same issue. Tried also with two different tenants, same result.
The files in VS Code are OK. I even restarted a VM I'm sure was working about a month ago, and it has the same problem.
Compiled with dt-sdk, they do compile. And they also run locally.
Antonio Sousa
3 REPLIES 3
Julius_Loman
DynaMight Legend
DynaMight Legend
Hi @AntonioSousa ,
this is caused by update of RedHat yaml extension is vscode. I also sumbled upon this on Friday afternoon. Already known issue and reported:  https://github.com/dynatrace-extensions/dynatrace-extensions-vscode/issues/285 . Just downgrade the yaml extension and disable it's autoupdate for a while to get this working again.
AntonioSousa
@Julius_Loman ,
Thanks so much! I downgraded almost everything, except the yaml extension. Working again!
Antonio Sousa
StrangerThing
Dynatrace Pro
Dynatrace Pro
Glad I thought to check the community for this! Been struggling with this issue for an hour at least. Thanks guys!
Solution Architect at Dynatrace
