Extensions
Questions about JBoss JMX Connection Pools
AntonioSousa
I'm trying to make the new JMX Connection Pools working, but still haven't managed. That is certainly because of the fact that I have to activate statistics for JBoss. But I still have a couple of questions:
Antonio Sousa
JamesKitson
Dynatrace Guru
Dynatrace Guru
I'll see if I can come across which agent version is required, the more important aspect for these though is the cluster version. The Dynatrace server nodes roll out the JMX extensions to the OneAgents so as long as they are relatively up to date and support that. The cluster version 1.207 has all the current connection pool extensions - I believe JBoss is included in 1.206 though.
The JBoss one will consume DDUs - the doc page here should be updated soon to reflect this.
Per pool it will consume 14 custom metrics which if you consume the per-host allotment of custom host metrics would account for .014 DDUs per minute, 613.2 per month, and 7,358.4 per year.
Great,
I'm on OneAgent 1.205 & SaaS 1.207, so ready to go 🙂
Antonio Sousa
