Extensions
RabbitMQ extension doesn't collect queues metrics
tesp11331
Visitor
Since some days, the extension does not collect the metrics related to the queues but only the ones related to cluster, nodes and virtual hosts.
Sometimes it works again and then it stops after a while, I tried also to reboot the extension bit it does not work.
Which could be the root cause ?
Regards
Pasquale
6 REPLIES 6
AntonPineiro
I think that is an ActiveGate extension. You can check ActiveGate logs to have more details.
Best regards
tesp11331
Visitor
 Yes it is but I do not see any detail about the issue in the logs.
Which logs are you checking?
Best regards
tesp11331
Visitor
I run the active gate diagnostic from Active gate deploy status.
Yes, but have you downloaded it and check datasources logs in relation to your extension?
Best regards
sujit_k_singh
Champion
Hello @tesp11331
Check this  /var/lib/dynatrace/remotepluginmodule/log/remoteplugin.log
and look for errors like timeout, HTTP 401, or failed to fetch queues.
