Extensions
Rabbitmq integration issue - rabbitmq as pods in Openshift
srinivaspbabu
Newcomer
We are trying to integrate Dynatrace managed with RabbitMQ in Openshift Pods. But while we trying with local load balancer ip still we facing error.
can any one help me on this!
3 REPLIES 3
p_devulapalli
DynaMight Leader
DynaMight Leader
Hi @srinivaspbabu , the extension you are trying to use is now deprecated, have you considered using the below?
https://www.dynatrace.com/hub/detail/net-rabbitmq/
Phani Devulapalli
Peter_Youssef
Leader
Hello @srinivaspbabu
Currently you have two options, as the highlighted feature has been deprecated by Dynatrace:
  • If the OA is currently installed proceed with Navigate > manage > Dynatrace hub > Rabbit MQ
KR,
Peter.
i have tried this, but it can't able to see the rabbitmq. I have tried with the local load balancer ip too,
