24 Feb 2022
05:04 PM
28 Mar 2022
02:14 AM
How do I add the following clustered network name to the WMI extension?
$cluster_network_name = 'msmqDemo'
$env:computername = $cluster_network_name
$env:_Cluster_Network_Hostname_ = $cluster_network_name
$env:_Cluster_Network_Name_ = $cluster_network_name
Yes, I have write a powerscript.ps to run every min as a schedule task which inget the collected MSMQ messages count.. I used the https://www.dynatrace.com/support/help/how-to-use-dynatrace/metrics/metric-ingestion/ingestion-metho...which is simple to work on. The issue is there's a need to set the following env in order to query the clustered MSMQ correctly. Hence, WMI extension is not able to meet this requirement.
