OTel
Disabling OpenTelemetry Span Sensor for individual workloads
Colin_Spratt
Frequent Guest
Our team is looking for a method to disable OpenTelemetry Span Sensor for individual workloads in a Kubernetes environment. By default, we'd like the feature to be enabled for all deployed java processes, giving teams the ability to turn it off if they manually instrument OpenTelemetry.
However, we can't identify any methods outside of the UI (i.e. via annotations or environment variables, like the technologies annotation) to disable the Span Sensor's dependency injection. We're aware of the UI capability to turn off injection for an individual workload, but we'd like to drive this injection setting via our deployment pipeline.
Any ideas if something like this exists?
Julius_Loman
DynaMight Legend
DynaMight Legend
Currently you can use settings API to manage the setting on individual workloads. Unfortunately, the workload has to exist in Dynatrace so you can know it's entityId. Then with setting api you can disable the OneAgent features. It's the same setting that you see in the UI.
Community freeze: read-only from October 22, 6:00 AM UTC, while we move to Discourse. Outage (~1h) on October 26 at 9:00 AM UTC. Learn more.
