OTel
Advantages and disadvantages with using OpenTelemetry over collecting data with the OneAgent
Benedikt
Participant
Hello all,
I am currently debating about using OpenTelemetry to collect data and then send it to Dynatrace or collecting data with the OneAgent.
Have you ever made any experiences with this?
My question is, if you think it is valuable to use OpenTelemetry instead of the OneAgent? What comes out-of-the-box with using OpenTelemetry and what is missing compared to the out-of-the-box functionalities from OneAgent?
In general, what would you say are the advantages and disadvantages with using OpenTelemetry over collecting Data with the OneAgent?
Greetings and thank you for your help,
Benedikt
13 REPLIES 13
radek_jasinski
Hi @Benedikt
I was preparing such a comparison for my client with advantages and disadvantages against OA. I attach it here (sorry if something is not coherent, because I put this text in the automatic translator, as I have the document in Polish:))
Otel:
Advantages:
1. OpenTelemetry is an open-source project that follows open standards for telemetry data (traces, metrics, and logs). This can be beneficial for ensuring long-term compatibility and avoiding vendor lock-in.
2. Being open-source, OpenTelemetry allows for customization and extensibility. You can modify or extend it as needed to fit your specific use case.
3. OpenTelemetry supports a broader range of programming languages, which can be advantageous if your stack includes less common languages.
4. a community-driven project, it benefits from the input and development efforts of a diverse group of contributors.
Disadvantages:
1. OpenTelemetry might require more effort to set up and configure compared to vendor-specific solutions like OneAgent.
2. Depending on your existing tools and platforms, integrating OpenTelemetry might require additional work.
3. While OpenTelemetry captures a wide range of telemetry data, it might lack some advanced features specific to vendor tools like Dynatrace.
OA:
Advantages:
1. OneAgent is designed to be easy to install and configure, offering a more plug-and-play experience.
2. Dynatrace offers advanced features like AI-powered analysis, automated root cause detection, and deep-dive diagnostics, which may not be available with OpenTelemetry.
3. Being part of the Dynatrace platform, OneAgent offers seamless integration with other Dynatrace features and tools.
4. OneAgent provides automatic and real-time instrumentation with minimal configuration.
Disadvantages:
1. Using OneAgent ties you more closely to the Dynatrace ecosystem, which could be a consideration if you aim for flexibility or anticipate changing monitoring needs.
2. Dynatrace is a commercial product, and using OneAgent might incur more costs compared to an open-source solution like OpenTelemetry.
Conclusion
- You prioritize open standards, need support for a wide range of languages, or require custom telemetry solutions.
- You want a more straightforward setup, advanced AI-driven insights, and tight integration with the Dynatrace ecosystem.
Radek
Have a nice day!
Hello Radek,
thank you very much! I briefly read through your post and I can say it is very well understandable.
That will help me a lot.
P.S. for others: other experiences would still help me, thank you 🙂
Slawa
Advisor
Keep in mind consumption costs.
You will have benefits in case of low traffic and high RAM config on hosts
Consider one agent in case of high traffic.
Otel billing per trace(traffic based)
One agent billing is per GB (RAM config based)
Hello Slawa,
thank you for your reply. Do you have any link providing the cost of Otel? I can't find anything about it.
fstekelenburg
DynaMight Pro
DynaMight Pro
Since this a still on-going topic, and development in both worlds are going fast in two years, this might be a good moment to re-validate the status and above comparison?
I have found a rather good and lenghty article that might be of interest:
https://dzone.com/articles/opentelemetry-vs-dynatrace
Kind regards, Frans Stekelenburg                 Certified Dynatrace Associate | Cegeka.com, Dynatrace Partner
fstekelenburg
DynaMight Pro
DynaMight Pro
Comparison: Dynatrace OneAgent vs OpenTelemetry Collector
1. Architecture & Approach
Dynatrace OneAgent:
- Proprietary, all-in-one agent tightly integrated with Dynatrace platform.
- Automatically discovers applications, services, dependencies, and infrastructure.
- Provides end-to-end observability with minimal manual configuration.
- Includes AI-powered Davis engine for anomaly detection and root cause analysis.
OpenTelemetry Collector:
- Open-source, vendor-neutral framework under CNCF.
- Collects telemetry data (traces, metrics, logs) and exports to multiple backends.
- Requires manual configuration of SDKs, instrumentation, and pipeline setup.
- No built-in analytics or AI—raw data only.
2. Features
Feature
Dynatrace OneAgent
Automatic Discovery
Yes
No
Dependency Mapping
Yes
No
AI/Root Cause Analysis
Yes
No
Security Monitoring
Built-in
No
Customizability
Limited
High
Standards Compliance
Proprietary
Open standards (OTLP)
Language Support
Broad, Dynatrace-specific
Very broad
3. Deployment & Configuration
Dynatrace OneAgent:
- Deployment: Single agent per host/container; minimal setup.
- Configuration: Mostly automated; advanced settings via Dynatrace UI.
- Maintenance: Managed by Dynatrace; updates are automatic.
- Deployment: Requires installing collectors and configuring pipelines.
- Configuration: Manual setup of exporters, processors, and SDKs.
- Maintenance: Requires ongoing updates and compatibility checks.
- Scaling: Complex at large scale; needs orchestration (K8s, etc.).
4. Knowledge & Skill Requirements
Dynatrace OneAgent:
- Low barrier: Plug-and-play, minimal coding.
- Requires knowledge of Dynatrace platform for dashboards, alerting, tagging.
- Higher barrier: Requires developers familiar with instrumentation, telemetry standards, and backend integration.
- Strong DevOps/observability expertise needed for pipeline design.
5. Financial Aspects
Dynatrace OneAgent:
- Licensing: Paid, subscription-based (cost depends on monitored hosts, metrics, and features).
- Manpower: Lower operational effort; vendor handles complexity.
- Licensing: Free (open-source).
- Manpower: Higher effort for setup, maintenance, and troubleshooting.
- Hidden Costs: Infrastructure for collectors, storage, and backend analytics.
6. Pros & Cons Summary
Dynatrace OneAgent:
✔ Pros:
- Easy deployment and maintenance.
- Full-stack observability with AI-driven insights.
- Automatic service discovery and dependency mapping.
✖ Cons:
- Vendor lock-in.
- Higher licensing cost.
✔ Pros:
- Free and vendor-neutral.
- Highly customizable and extensible.
- Broad language and ecosystem support.
✖ Cons:
- Complex setup and scaling.
- No built-in analytics or AI.
- Requires significant engineering effort.
7. Recommendations
- Choose Dynatrace OneAgent if you want turnkey observability, minimal setup, and advanced analytics.
- Choose OpenTelemetry Collector if you need vendor neutrality, cost control, and flexibility, and have strong in-house observability expertise.
fstekelenburg
DynaMight Pro
DynaMight Pro
Anyone to validate or comment on the above AI summarized comparison?
@fstekelenburg There are still many paths you can choose from. It also depends on the workloads you run. Generally, the OTEL path (using OTEL for instrumentation) involves much more work, especially when it comes to finetuning the collection. For example, when it comes to sampling of traces.
For some of the workloads, the OTEL is the path to go (if Dynatrace does not support particular technology or framework). OneAgent on the other side provides much more features than what OTEL is able to provides (bizevents capture, RUM sensors, live debugger, ... ).
I'd say - if you need any custom instrumentation (your domain specific) or metrics from your app, OTEL would be my choice (except maybe for SpringBoot/Micrometer metrics where Dynatrace did a great job with the micrometer dynatrace registry).  Some of the frameworks do have OTEL support, but there is no Dynatrace support. You should also consider your overall architecture.
As for now, if your backend is Dynatrace, I'd choose OneAgent for all the workloads where there is a direct support. Choose OTEL for technologies where support in OA is not available. Choose OTEL if you need any custom code instrumentation or metrics to be sent. Choose OTEL instrumentation if you require immutable code (Dynatrace is added typically at runtime and instrumentation does not work without a Dynatrace server anyway). Consider OTEL cost and maintenance (mostly, you need to manage the collection layer).
Babar_Qayyum
Hello @Julius_Loman @fstekelenburg
Thank you for providing the link and the comparison summary.
Do we have any success or failure stories regarding this transition (from OneAgent to OTEL)?
Babar Qayyum
My lessons learned (considering Dynatrace as the backend)
  • It depends on the workloads you need to observe. Sometimes it's inevitable to use OpenTelemetry
  • Licensing can be a significant difference (often in favour of the OneAgent solution), especially if you are on classic licensing or use Dynatrace Managed
  • Dynatrace Managed has much worse support for OTEL when it comes to trace data -finding traces by span attributes works, for example, only on the last 24h time span. Filtering on common trace data, such as HTTP status, is way more complicated, as it does not match the attributes users are used to.
  • There can be a noticeable overhead of managing the OTEL collectors, exporters or agents - that's generally an issue.
  • Dynatrace currently does not have sampling-aware metrics from OTEL ingested trace data. If you do sampling on the collectors or exporters, your service metrics will be inaccurate, as those are calculated from ingested traces.
Generally, my recommendation would depend on your goals, intentions and your current situation.
Babar_Qayyum
Hello @Julius_Loman
I appreciate your feedback. I may return with additional points for discussion.
Babar Qayyum
DavidFT
Participant
We also tried to compare both technologies and here is our conclusion. We may be wrong on some criterion, if so please feek free to critisize.
#CriterionOneAgentOpenTelemetry
General
1Auto-instrumentation of any tech type and environment (VM/K8S/TAS)YesPartial (K8S at a minimum)
2Automatic discovery of IT assets / infrastructureYesNo
3Global IT infrastructure topology visibility (Smartscape)YesPartial
4Logs/traces/SQL queries/... correlationYesYes
5Effective AIYes (as it relies on Smartscape)No
6Vendor neutralityNoYes
7CostsPer host/GiB memory (typically preferred for high traffic)Data volume (typically preferred for low traffic)
RUM
8RUM auto-instrumentationYes (automatic client-side JS injection)Partial (manual on apache-nginx / auto-instrumentation on NodeJS)
9Apdex performance indicatorsYesNo
10Automatic web page construction analysis (waterfall)YesNo (manual)
11Mobile observabilityYesNot tested
12Automatic user action / services correlationYesNo
13Session replayYesNo
Advanced Features
14Business event creation from APIsYesNo
15Dynatrace extensionsYesNo
16CPU profilingYesNo
17Memory profilingYesNo
18On-demand memory dumpsYesNo
19Code introspectionYesNo
