08 Dec 2023 09:34 AM
08 Dec 2023 09:53 AM - edited 08 Dec 2023 09:53 AM
Hi @akataoka
The impact on the performance of the monitored components should be hardly noticeable and should certainly not reach 30%. Only during the first start-up there may be a higher load as instrumentation, class browsing, etc. are performed.
There may be a number of variables that are causing the higher load and I recommend contacting support on this issue.
Radek
08 Dec 2023 12:36 PM
Hi, folks
Regarding of process CPU overhead of code module , we have been asked to explain from customer again and again. However we could not find related document and blogs in anywhere. In our experience, process CPU overhead of Java code module seems be about 5 to 8 %. Please share actual data you have if possible.
Regards
