13 Mar 2020 10:20 AM
Hello friends, is there a config that can do such a thing ?
(Avoiding the traffic collected by Environment Active Gate to be re-routed to the Cluster Ag)
Thank you
13 Mar 2020 11:06 AM
Yes, you can.
1. You have to set up MSGRouter = false at Cluster AG.
https://www.dynatrace.com/support/help/shortlink/sgw-configure#section-collector-
In that case Environment AG will hae to pick a cluster node to route the traffic.
2. Around June 2020 we will deliver a new feature called Network Zones - that will enable you to configure how you would like to set up routing path.
13 Mar 2020 11:36 AM
Can I be specific on which Env Active Gate I do not want to communicate with the Cluster Active Gate?
13 Mar 2020 01:02 PM
When we introduce Network Zones - yes. Now you can only block traffic with your firewall or iptables.
15 Mar 2020 09:13 AM
Thank you very much @Radoslaw S.
16 Mar 2020 12:06 PM
Like @Radoslaw S. said, until the Network Zones feature is released, users will have to resort to firewall blocks. We had to block all oneagent traffic out to our DMZ activegate that supports our UFO's Davis, Synthetics and so much more.
16 Mar 2020 03:35 PM
... network zones... 😄
16 Mar 2020 03:36 PM
