Open Q&A
Data Retention Difference between Metrics and RUM User Sessions
abnerlusung
Advisor
I'm looking for answers for these questions.
How come RUM User Sessions has 35 days while metric has 5 years?
https://www.dynatrace.com/support/help/manage/data-privacy-and-security/data-privacy/data-retention-...
Are they not pulling data from the same table?
Example:
select bounce from usersession
builtin:app.web.bouncedSessionRatio
Abner
3 REPLIES 3
Romanenkov_Al3x
DynaMight Champion
DynaMight Champion
Hello.
It can be simplified with that there are two storages. One for operation data, another - long-therm storage.
First is ElasticSerach, second is Cassandra DB.
For example you have create User session. You go to the instrumented site and do some work, for example three user actions. All of these user actions are now in ElasticSearch in JSON as separate objects.
Dynatrace do some background work and got some metrics for long therm for these objects.  After 35 days when infromation will gone (3 user actions will be deleted) from ElasticSerach we still have metrics from long-therm storage - Cassandra.
This is only an example of work. The engine works much more difficult as I described.
Romanenkov Alex
DT_NGINX_FORCE_UNKNOWN_VERSION_INSTRUMENTATION=1
Hi Romanenkov Alex,
Does this metrics includes the USQL custom metrics?
Abner
Yes, it should.
Senior Product Manager,
Dynatrace Managed expert
