30 Mar 2023 06:36 PM
Hi Everyone,
What's the diference between userevent.page and useraction.name?
I was making some Funnel charts and then I realized something when executing some query:
This is a Funnel using userevent.page statement:
On the other hand, this is another Funnel but using useraction.name statement:
Could you help me understanding the function of each statement?
Thanks in advance
30 Mar 2023 08:02 PM - edited 30 Mar 2023 08:03 PM
In general, the difference between an action and an event is their context of occurrence. Both indicate state changes. But an action results from the execution of a function, while an event does not necessarily have to. Hence, an event may occur spontaneously. In Dynatrace user action name constructs a name also based on User event type, for example, click on..., loading of page..., or keypress on...
Radek
30 Mar 2023 08:33 PM
Hi @radek_jasinski ,
Thank you for your response. I understand now the difference. So, what would be recommendable at the moment of creating a Funnel chart, to use userevent or useraction?
30 Mar 2023 08:38 PM
I recommend useraction.name 🙂
Radek
31 Mar 2023 01:27 AM
Thank you so much for your help
