04 Sep 2018
07:48 AM
28 Sep 2022
02:54 AM
Hi to all
if I disable monitoring on a host (settings option in the dynatrace admin console), does the agent continue to consume the outgoing bandwidth when talking with the dynatrace saas environment or is it silent?
Thanks a lot
Hi Frédéric,
as you are able to re-enable monitoring from the console and OneAgent doesn't open any listening ports on the monitored machine I would assume that it polls the server periodically to check if there has been a change of configuration. So you would still have some traffic.
If you don't want that you can stop the OneAgent Service from the command line: https://www.dynatrace.com/support/help/deploy-dyna.... You would then have to use the command line again if you want to continue monitoring.
best regards
Franz
