Open Q&A
Fetch data using Query from Mongo DB and AWS RDS
Munzir
Contributor
Hello there,
We are working in a Managed Environment and have a requirement where we have to fetch data from the MongoDB and AWS RDS using queries. For this requirement, which extension will be used?
And can we create a metric using the queries to fetch data and populate it real-time in the dashboard?
MongoDB is an on-Prem DB where we have OneAgent installed in Infra mode, whereas we are using AWS integration for AWS.
AntonPineiro
You can check:
Best regards
