Group 20-30 management zones into 1 management zone
divyangsinghal1
Visitor
The ask here is, we need to club 20-30 management zones into 1 management zone, to pull out data for the customer.
If this can be achieved in some way by creating a new master management zone where we can add the other 20-30 management zones.
Please suggest.
Divyang
5 REPLIES 5
AntonPineiro
DynaMight Leader
DynaMight Leader
Maybe you can base management zone logic base on tags. Entities can have more than one tag, it means, it can be tagged with "mz1" and "global-mz", same with "mz2"... Then, entities with "global-mz" would be entities in "mz1" and "mz2".
Best regards
radek_jasinski
You can also make one Management Zone that will contain rules that map components from other MZs. For this, I would use an API with which you take the configuration from the Management Zone and create a new "global" one based on it
https://www.dynatrace.com/support/help/dynatrace-api/configuration-api/management-zones-api
Radek
Have a nice day!
AntonPineiro
DynaMight Leader
DynaMight Leader
A product idea has been raised about this topic.
Hi Anton,
Thanks for raising a product idea.
Actually i have also already raised a product idea for the same: Grouping multiple management zones together into 1 master management zone - Dynatrace Community
It means, I had just linked your product idea, I had not created a new one.
Best regards
