Open Q&A
Import or Save Problem Card Page (Past or Present)
WD974079
Newcomer_
Is there a way to import or save Problems card page for a specific site (Past or Present)???
(see screenshot)
michiel_otten
Champion
Hi there,
What do you exactly mean with "import or save"? Do you want to pull the problems out of Dynatrace and import in a different tool or perhaps an Excel document? To do that you could use the problem API:
https://www.dynatrace.com/support/help/dynatrace-api/environment-api/problems-v2/problems/get-proble...
You can also use this API to query the problems to filter a specific CI  / Tag etcetera.
KR.
Michiel
#Performance matter!
radek_jasinski
You can use the API as Michiel wrote in the previous comment. Personally, I also sometimes use an extension for Chrome browser called GoFullPage - Full Page Screen. With it you screen the full page to PDF and you can use that as a report - of course it's workaround.
Radek
Have a nice day!
