14 Nov 2017 12:30 AM
Do we have an option in DT where we can review the code for the application which is being monitored by DT in client.
14 Nov 2017 01:00 AM
If you're referring to the "decompile source code" option that is possible in AppMon then no I don't believe this is a feature in Dynatrace at the moment (maybe a good RFE/idea). But for any services and requests you should be able to drill down to an individual PurePath and there is a "code-level" tab you can select to view the tree.
This blog post from today does a good job of showing how to get to that:
https://www.dynatrace.com/blog/finding-performance...
James
