Open Q&A
Mapping Extracted Metric to Management Zone
Rohitk
Participant
Hi All
I created a metric using the metric extraction feature (from log ) and want to add it to a specific management zone, but I am unable to do so. Does anyone know how to add a specific metric to a management zone, or if it's possible?
Rohit
3 REPLIES 3
erh_inetum
Champion
Hi Rohit,
I modified my previous answer because it was wrong. Thanks @AntonPineiro for letting me know
You can add a new dimensional data rule type in a Managment Zone and selecting Metric Type. And then, selecting your log metric.
Here you have an example:
In the documentation you have more examples related to this.
Hope it helps.
Elena.
In addition to that and just for maintenance purposes I suggest you give a criterion to each team, I use log.BU (Business Unit) for example log.dynatracecommunity and then I use the dimensional metric with startswith. It is easy to mantain and to know in a future if the metric still have sense, and if someone uses something different they cannot see the metric.
Rohitk
Participant
@erh_inetum
 Thanks for your suggestion. As you mentioned is working and able to add the metrics to the management zone.
@DanielS
Thanks for your response. As you mentioned, we are also following the same approach, which helps in easy identification.
