07 Feb 2025 06:41 AM
Hi All
I created a metric using the metric extraction feature (from log ) and want to add it to a specific management zone, but I am unable to do so. Does anyone know how to add a specific metric to a management zone, or if it's possible?
Rohit
07 Feb 2025 07:34 AM - edited 07 Feb 2025 10:16 AM
Hi Rohit,
I modified my previous answer because it was wrong. Thanks @AntonPineiro for letting me know
You can add a new dimensional data rule type in a Managment Zone and selecting Metric Type. And then, selecting your log metric.
Here you have an example:
In the documentation you have more examples related to this.
Hope it helps.
Elena.
07 Feb 2025 01:37 PM
In addition to that and just for maintenance purposes I suggest you give a criterion to each team, I use log.BU (Business Unit) for example log.dynatracecommunity and then I use the dimensional metric with startswith. It is easy to mantain and to know in a future if the metric still have sense, and if someone uses something different they cannot see the metric.
07 Feb 2025 03:51 PM
Thanks for your suggestion. As you mentioned is working and able to add the metrics to the management zone.
Thanks for your response. As you mentioned, we are also following the same approach, which helps in easy identification.
