11 May 2023
08:58 AM
12 May 2023
07:38 AM
When installing AG for windows, there is 4GB requirement needed to be allocated for this directory %PROGRAMDATA%\dynatrace\gateway\tmp and it is for cached OneAgent installers and container images. I was wondering what does it really mean and why is it important?
Appreciate any feedback, thank you!
-Leona
11 May 2023 12:51 PM
You may download installers via our rest.api or fetch container images using docker client directly from the Environment ActiveGate. In this case AG will cache the binaries and/or images on disk in the above directory to optimize the process. Additionally binaries for OneAgent automatic updates will also be cached there.
