Open Q&A
Monitor Informatica PowerCenter using Dynatrace
AmitThorat
Newcomer_
We can see extension for the IICS not for Informatica PowerCenter in Dynatrace. Can you help with procedure to monitor Informatica PowerCenter using Dynatrace?
PacoPorro
Dynatrace Guru
Dynatrace Guru
There is no extension for Informatica PowerCenter.
An option is to use the logs from Powercenter in Dynatrace.
Take a look on
https://docs.dynatrace.com/docs/observe-and-explore/logs/lma-log-ingestion-via-oa/lma-custom-log-sou...
