15 Oct 2020 04:16 PM
Monitor Prometheus metrics to Dynatrace : does it consume Davis data units ?
15 Oct 2020 05:06 PM
I would recommend signing up for this power Demo Session:
You would be able to pose this question along with additional ones to a Kubernetes and Prometheus Expert!
15 Oct 2020 07:34 PM
You should consult this page:
https://www.dynatrace.com/support/help/reference/davis-data-units/
If you are ingesting through the API, it should consume DDUs:
If you are using Kubernetes, some specific rules seem to apply for now:
