29 Aug 2019 03:45 PM
We need monitor SSL certificate expiry and we want to get the alert X-days before it expires and just if it is expired.
There are same different implementation, for example :
29 Aug 2019 06:42 PM
In general you will have to create custom metric that will present certificate validation time as number of days. In such way you will be able to create threshold on such metric. But to get such value I think you will have to create ActiveGate plugin that will call your hosts every minute (default behavior), fetch date time of certificate expiration and than calculate number of days. After this operation such data should be send to dynatrace as custom metric with dimensions for all host separately. This will give you option for creating threshold and event for such metric,
12 Jan 2020 09:37 PM
I've written a OneAgent plugin for SSL/TLS certificate expiration check (also does notification in advance). If you need to check certificates locally for any process running on a host monitored by oneagent.
If you are interested, you can download it from https://github.com/juliusloman/dynatrace-oneagent-plugin-sslcertcheck.
08 Dec 2020 03:31 PM
Hello! I have installed the plugin but is fails with this message: Error: No module named 'asn1crypto'. What can we do?
