23 Jan 2020 07:58 PM
I have a basic question - We are planning to use Dynatrace monitor several Java applications that are deployed on an application server deployed on virtual machines. The virtual machines themselves are installed on windows ESX hosts.
My understanding is that OneAgent gets deployed on the ESXHost. Do we also need to install OneAgent on the virtual machine separately?
		23 Jan 2020
		08:15 PM
		10 Dec 2024
		10:16 AM
To monitor java apps - you need to install OneAgent at each VM.
To monitor ESX hosts - you need to set up VMWare monitoring.
See https://docs.dynatrace.com/docs/shortlink/section-technology-support#vmware
23 Jan 2020 08:29 PM
Thanks for the quick response.
I had a quick followup question to understand your answer fully -
1. If we have 2 or more virtual machines on a single physical host, then do we still need a separate OneAgent for each virtual machine?
2. For the physical host, we only need to monitor the basic metrics such as CPU, Memory and Network usage. Do we still need to setup VMware monitoring for these basic requirements? Can we get these basic host metrics without configuring VMware monitoring?
23 Jan 2020 08:51 PM
1. Yes
2. Yes. Otherwise you can monitor them by other means - eg through plugin.
Further reading: https://www.dynatrace.com/support/help/technology-support/cloud-platforms/vmware/basic-concepts/how-...
23 Jan 2020 08:58 PM
