Open Q&A
OneAgent 1.309 - uWSGI deep monitoring problem
pawel_harbuz
Helper
Thanks to the Dynatrace team since the OneAgent version 1.309 we are able to monitor Python applications using OA code module. I've successfuly instrumented a Gunicorn application and I'm able to see transactional data. But if I try to instrument an uWSGI application, I get the following message:
Is the uWSGI supported somehow by OneAgent? If so, how to instrument it? Every OneAgent feature regarding to Python is enabled. Also I've enabled Python monitoring globaly and created a monitoring rule for uwsgi, but nothing changes.
Paweł
4 REPLIES 4
That does not satisfy me, because the autodynatrace is an open source solution, I'm rather talking about native instrumentation that has been introduced by Dynatrace in OneAgent recently. There is nothing mentioned in the documentation about uWSGI.
Paweł
Ok, thanks for your feedback.
Kindly keep us posted upon finding the solution.
BR,
Peter
pawel_harbuz
Helper
I've received information from the Dynatrace team that currently they don't support uwsgi.
