Open Q&A
Problem with metric event
radek_jasinski
In one of my environments, I need to send an alert when metrics are not sent from Azure to Dynatrace. I have a basic integration with Azure configured and am collecting information about the VMs (CPU, memory, disk). Unfortunately, no metrics are available to inform me, for example, that a VM has been shut down or restarted. We have prepared a metrics event that has the "Alert in missing data" option enabled.
builtin:cloud.azure.vm.cpuUsage:filter(and(not(in("dt.entity.azure_vms,entitySelector("type(azure_vm),tag(~"(Azure)V:XXXX~")"))))):splitBy("dt.entity.azure_vm")))
Of course, the threshold is 101% CPU utilisation so that it does not report other deviations.
The preview shows correct operation. Unfortunately when running in a production environment the alerts are reported randomly and close a minute later. This happens for several vm's at the same time. The time windows are set as shown in the screenshot:
Radek
Have a nice day!
6 REPLIES 6
Mizső
Hi @radek_jasinski,
Have you tried this metric for host restart? builtin:host.uptime
I hope it helps.
Best regards,
Mizső
Hi @Mizső
I haven't tried it. I understand that this metric works for VM's in Azure?
Have a nice day!
Unfortunately, this metric is not available in my configuration. I don't have OA installed on my hosts.
Have a nice day!
Mizső
Hi @radek_jasinski,
Sorry I missed this information.
Best regards,
Mizső
radek_jasinski
I'm reporting the problem to support - I'll let you know if I find out anything.
Have a nice day!
radek_jasinski
On the recommendation of support we have increased the value for violating samples to 24 and for the moment this has helped:)
Have a nice day!
