23 Oct 2025
10:49 AM
31 Oct 2025
10:17 AM
Michal_Gebacki
I'm reaching out for help in understanding the relationship between segments and Security Event and Problem data in Dynatrace.
I'm trying to create a segment that would allow users to work with a single unified segment across the different Dynatrace interfaces.
However, my segment doesn't seem to cover these data types:
For Security Events, it's possible to include them in the segment, but it seems impossible to apply a filter based on tags.
For Problems, they don't appear in the list of available entities. I believe they need to be handled through Events using entity_tags.
Could you share the methods you use to surface Security Event and Problem data within your segments?
