Sending AWS tags in Problem notifications
JAR1
Contributor
Hello everyone
I am integrating the sending of notifications by mail, and I need to send a tag that comes from aws. This tag has this form (in square Brackets): [AWS]Environment
In Tag configuration it is indicated that it should go like this -->  {Tags[key]}
How should this configuration be done? I have tried like this: {Tags[[AWS]Environment]}
But it does not work.
Any ideas?
Thanks in advance
Greetings.
JAR
AntonPineiro
No idea in relation which syntax would be correct or if that is possible.
But some workarround might be creating your own tag base on "[AWS]Environment", and then, {Tags[key]} should work.
I hope someone here can provide a better answer than mine.
Best regards
@AntonPineiro is correct, you can use the "[AWS]Environment" tag and use that to create a Dynatrace tag, based on the AWS tag. That will allow you to use it the way you want.
