27 Jul 2026 04:33 PM
Hello Community,
We monitor around 600+ network devices in Dynatrace using both SNMP polling and SNMP traps through Three ActiveGate servers.
Our challenge is that when an ActiveGate is replaced or decommissioned, we may need to update SNMP settings, trap destinations, firewall rules, or allowed SNMP manager IPs on many network devices.
We are considering using a Load Balancer VIP in front of the ActiveGates.
The idea is:
Has anyone implemented this type of setup?
I would like to know:
Any guidance or real-world experience would be appreciated.
Thank you.
28 Jul 2026 07:33 AM
Hi Tahir,
A VIP can potentially be used for SNMP traps, as discussed in the following link:
https://community.dynatrace.com/t5/Extensions/VIP-for-SNMP-Trap/m-p/243298
However, SNMP polling operates in the opposite direction, from the ActiveGate to the network device. Therefore, a standard inbound load-balancer VIP would not address the polling requirement.
If the objective is for all polling ActiveGates to appear to the network devices as a single permitted SNMP manager IP, a stable outbound SNAT address could be considered. Alternatively, the network devices could allow a dedicated and stable ActiveGate subnet.
NAM may also work through a stateful SNAT configuration, since the checks are initiated from the Synthetic-enabled ActiveGate toward the monitored targets. However, this should be validated in the target environment.
In summary, a single load-balancer solution would not cover both traffic directions:
These approaches are technically feasible in principle, subject to the correct network configuration. For the trap VIP in particular, the original device source IP should be preserved, and each trap should be forwarded to only one ActiveGate to avoid incorrect source identification or duplicate processing.
As neither approach is clearly documented by Dynatrace as an officially supported reference design, I recommend validating both through a controlled POC and confirming the proposed design with Dynatrace Support before production deployment.
Kind regards,
Hamdy
