27 Jun 2018 01:43 AM
We are evaluating OneAgent with NodeJS ver 8.x micro-service which uses expressJS and mongoDB.
Question 1 - Do we need to use OneAgent SDK?
Question 2 - Does Dynatrace OneAgent SDK use async hooks?
27 Jun 2018 05:09 AM
Hello @Vineet B.
The Dynatrace OneAgent SDK enables you to instrument your application manually to extend end-to-end visibility for frameworks and technologies for which there is no code module available yet. With the SDK, you get full access to all analysis and monitoring functionality, including auto-baselining and AI-based root cause analysis.
With the Dynatrace OneAgent SDK, you can:
Have a look on the below blog for more insight.
https://www.dynatrace.com/news/blog/dynatrace-onea...
Babar
27 Jun 2018 08:16 PM
Thanks @Babar Q. for the helpful answer.
So without OneAgent SDK we should be able to look at NodeJS metrics? We are not seeing those.
I am also not seeing detailed CPU consumption - nodejs service requests CPU - show code level - hotspots. I get "No method hotspots contributing to CPU time available.
  Please ensure Dynatrace OneAgent version >=1.131 is installed." message.
27 Jun 2018 08:21 PM
So even without OneAgent NodeJS SDK we should see NodeJS metrics? I am not seeing NodeJS metrics at process level.
Also not seeing "code level" - service hotspots. I am seeing a message "No method hotspots contributing to CPU time available.
  The
 analyzed requests contain no method hotspot information. This can
happen in case of very fast requests or due to other influences like
garbage collection. Please select a bigger timeframe or adjust the
filter criteria to analyze more requests."
