Open Q&A
Using workflow for problem notifications
AK
Pro
Hello There,
I'm trying to convert a problem notification (custom integration) using workflow.
I chose 'Davis problem trigger' and then in subsequent step it is http request which would be having payload.
This isn't successful and went into the error:
Unhandled failed task(s) during workflow execution:
http_request_1:
Error: error sending request for url (https://test1.company.com/): client error (Connect): tcp connect error: Connection timed out (os error 110): Connection timed out (os error 110)
The associated host/URL is already added under allowed list ( Setting --> General --> External Requests)
Has anybody done it with success, please guide.
AK
Julius_Loman
DynaMight Legend
DynaMight Legend
Is your destination (https://test1.company.com) reachable from the internet (your SaaS environment)  or are you using EdgeConnect?
Yes, it worked post deploying EdgeConnect. Thanks for the inputs.
AK
