25 Dec 2017
		07:39 AM
		14 Feb 2023
		11:43 AM
		 Karolina_Linda
			Karolina_Linda
I understand that we can monitor applications at the code level only when we enable "deep monitoring" of process groups.
Then, what can we monitor when we disable deep monitoring of process groups?
(Or what cannot we monitor?)
Kohei
27 Dec 2017 02:59 PM
Disabling deep monitoring of processes will still get you infrastructure metrics, like CPU, Memory, etc. but you will not get any of the deep dive into services. On the process level, you will not have log monitoring without deep monitoring is enabled.
Hope this helps,
Hayden
11 Jan 2018 09:24 AM
Thank you for your comment!
I understand that we can monitor only infrastructure metrics by disabling deepmonitoring.
Thanks for your help.
Kohei
19 Jun 2023 04:00 PM
If a oneagent is running in full stack mode, but not deep-monitoring processes, is that equivalent to a infra mode operation or do we get additional metrics/insights even with deep monitoring turned off ?
02 Jan 2018 11:33 AM
You can also use Synthetic or Real user monitoring for web applications, web sites or native mobile applications without "server side" code level monitoring. Or if it is not a web application, you can soon use our real user monitoring (RUM) OpenKit API for bringing real user monitoring to non HTML or native mobile applications. The RUM OpenKit API is currently in early access.
11 Jan 2018 09:34 AM
So you mean, is it possible to use RUM without deep monitoring?
Thanks for new information!
I'm interested in UEM for non HTML/native mobile applications.
I'll try do that after the release.
Kohei
