22 Nov 2018 02:25 PM - last edited on 20 Jul 2023 01:19 PM by Radoslaw_Szulgo
I'm looking into the capabilities of Dynatrace Managed for monitoring of vCenter, and although I can find some good documentations of what metrics will appear in the user interface I have not been able to locate any information concerning the types of events / problems that Dynatrace would potentially raise (i.e., what alerts could be raised). Is this information documented anywhere? Note that I am specifically interested in knowing whether Dynatrace would raise events/problems for vCenter issues and also for any VMs (without OneAgents deployed).
22 Nov 2018 02:41 PM
Here is an overview of important events that are raised by Dynatrace, it also contains some event types coming from vCenter, e.g.: VM motion event.
https://www.dynatrace.com/support/help/monitor/pro...
Best
Wolfgang
22 Nov 2018 02:46 PM
Probelms on an infrastructure level will be raised for your ESXI hosts, for example for CPU saturation, disk latency,...
With the integratoin it can also detect VM Migratoins as a potential Root Cause for Problems.
Problems for VMs without an OneAgent will also be raised. Here is an example for a Problem with CPU Satuarion of VM not instrumented with a One Agent:
22 Nov 2018 05:04 PM
Hi Jeff,
Adding to the previous answers, you can also find the type of VMWare-related problems automatically detected by the Anomaly Detection engine in the Settings->Anomaly Detection->Infrastructure->VMWare
Steve
