27 Jul 2024 12:47 PM - edited 27 Jul 2024 12:50 PM
Hi Folks,
I have two issues basically.
1. Unable to replay browser click-path locally
This synthetic monitor is created manually, when I tried to replay it locally it just minimize the main window and monitor fails stating that “playback window minimised”
The step where it fails is the manually added navigation step, and this launches as pop-up window. This step is closing main window.
2. Screenshot are not populating after certain steps
As local playback is failing, I’m not able to debug is it. Hence, I used on-demand execution to debug it successfully.
Now, dilemma is for the scheduled runs, screenshots are not showing from navigation step.
As per my observation, for both of the two issues, it’s happening because “navigation” step launching in popup window.
Has anybody came across this and resolved it by any way?
Kindly help.
AK
29 Jul 2024 07:26 AM
Hi All,
Has anybody created browser click-path manually, and came across this situation.
AK
29 Jul 2024 11:28 AM
I have just never got "playback window minimised”.
Have you installed recorder extension in Google Chrome browser and allow incognito mode?
Best regards
29 Jul 2024 12:17 PM
This is likely related to the pop-up trying to close the original navigation window.
For the screenshots, is the correct target window being used? Do the actions do anything? Are there any waterfalls etc? This is probably easiest investigatiged in a Support ticket
