21 Jan 2022 07:10 PM
Dynatrace had to grouped all performance threshold violations for the synthetic into one problem, so all the steps that are tied to the problem are going to be highlighted in red.
Kindly try to fix the issue and Generate each and every affected event as individual problem and send an alert on performance threshold violations.
30 Mar 2022 06:25 PM
This request kind of goes against the grain of the AI. The system review everything and combines them into a single alert as long as they are all related together. SO you want a single alert on every aspect of a given problem? If that's the case, you'll need to put in a RFE for that.
