HA for private Synthetic location
amitbsht321
Contributor
Hi Team,
We are using are DT SaaS. For intranet application, we are planning to deploy AG as private Synthetic location.
Is their a way to configure HA for private Synthetic location ??
Thanks in advance!!
Regards
Amit Singh Bisht
6 REPLIES 6
Julius_Loman
DynaMight Legend
DynaMight Legend
You can install multiple private synthetic locations and assign the synthetic tests to all of them.
Hi Julius,
Appreciate your response.
Just wanted know, will it cause any impact on synthetic licensing ?
Amit Singh Bisht
Jacek_Janowicz
Dynatrace Pro
Dynatrace Pro
Or you could have two or more nodes (Synthetic ActiveGates) and assign them into single private location. In case of failure of one AG, test will be executed from 2nd, 3rd etc.
Best Regards
Jacek
Hi Jacek,
Thanks for your prompt response.
Will it cause any impact on licensing part for synthetic.
Regards
Amit Singh Bisht
Regards
Amit
There is no impact on licensing as Synthetic charges are by the number of actions executed rather than the number of ActiveGates.
Hello Hanna,
Thanks for clearing my doubt.  Appreciate your quick response.
Amit Singh Bisht
