25 Apr 2025 08:25 AM
How to enable browser monitoring for the url with sso authentication?
The url doesn't have username and password input but directly logins via sso
25 Apr 2025 12:29 PM
You can check Supported authentication methods in Synthetic Monitoring.
Best regards
25 Apr 2025 12:57 PM
@anton Thanks for your reply.
we are using smart pass card authentication, so we don't use credentials for the sso login.
What can be done in this case?
25 Apr 2025 01:25 PM
I think that is not supported in Dynatrace Synthetics but lets wait anothers answers.
Best regards
25 Apr 2025 01:37 PM
Check if this thread helps you
