How to import Postman Collection into HTTP Monitor
JeanBlanc
Contributor
Hello Community 🙂
I'm looking for importing Postman Collection into HTTP Monitor.
Is there any way or tool to automate this ?
Maybe converting Postman Collection in HTTP monitor script ?
Thank you in advance.
Jean
6 REPLIES 6
DanielS
Hi @JeanBlanc you can do some scripting or pre/post executions scripts in HTTP Monitors
May be is an approach for your goal.
The true delight is in the finding out rather than in the knowing.
Mizső
Hi @JeanBlanc ,
I do not have idea for converting postman collection to http monitor.
But you can use to import http monitors via simple API calls or Monaco (also API calls, gitops way).
I would suggest to create manually one http monitor in DT and then donwload it with Monaco. Then you can use it as a template. In my case there were three http and one browser monitor in a test environment.
If you created your http monitoring collections based on the tempalate you can delpoy it with Monaco. From a test system I downloaded a sample collection of http monitors. In these test monitors I used different frequency, locations and simple gets.
I hope it helps.
Best regards,
Mizső
pahofmann
I don't think there is anything yet.
Shouldn't be to hard to write a small script that converts an exported postman collection into one/multiple HTTP monitors you can import via API though.
JeanBlanc
Contributor
Thank you @Mizső@DanielS & @pahofmann for your Synthetic Monitoring automation ideas 😊
Maybe a future Dynatrace Extension for Postman 💡
dannemca
Maybe an Idea to be requested.
https://community.dynatrace.com/t5/forums/postpage/board-id/DynatraceProductIdeas
