Synthetic Monitoring
Integrate the synthetic monitor to APM tool
Adi_10
Guide
Hi Community,
I am a newbie in Dynatrace Admin still need to integrate the synthetic monitor (Browser click path / http ) to APM tool in my project having no help around.
Can you please help me the ways out.
7 REPLIES 7
p_devulapalli
Leader
Synthetic Monitoring is one of the key ingredients of a successful digital experience monitoring strategy. The main use cases we have seen it used is for Availability and Performance Baselining. Join this Performance Clinic and hear from Philipp Kastner, Technical Product Manager at Dynatrace, on
Synthetic Monitoring is an essential part of Digital Experience Monitoring and as such needs to allow monitoring of not only publicly accessible applications but also private ones. Another aspect to have in mind is to allow the SLA measurement from within the important organizational structures ...
@p_devulapalli  I am going through the videos that you have sent, Onces I found the solution will let you know thanks for your help.
Peter_Youssef
Leader
Hello @Adi_10
Feel free to review Dynatrace documentation for full info about your inquiry, where you will find detailed demonstrations, practical examples and best practices : Synthetic Monitoring
KR,
Peter.
Hi Peter, I have gone through the documentation but still looking more on integration,
Like I have created 10 different synthetic monitors for different URL they are now in unavailable stage, now i want to integrate them by API to other apps/make them available.
Hi @Adi_10
  • If your target to correlate the configured synthetics with the monitored apps, if it's the case on each application page you can link the required synthetic with each app.
  • Another way is to correlate the synthetic to the monitored app as per example below.
Through API on the Synthetic page click the three dots
For the API usage, you should have cluster admin permissions or have the below privileges.
On the user menu > environment API v > Synthetic > Post
So you will be able to create synthetic monitors without having to access the UI through the generated Rest API.
KR,
Peter
Thank you Peter it helped me as I needed, and I moved forward to next topics.
Thanks @Adi_10 for keeping us posted.
keep up the good work.
BR,
peter
