Maintenance window over specific location
mukunda
Observer
I would like to set a maintenance window over a specific location and not over all locations for a synthetic monitor. What settings are to be chosen for that in terms of Entity type ?
AntonPineiro
I think that is not possible. If you do not want to be running a location, you need to remove it in that Synthetic monitor, manually or using API.
Best regards
marina_pollehn
Champion
II think you can set one filter to include only the monitor(s) which you want to select and also select the location as a filter. Pls let me know if it works (I also didnt have the chance yet to try it in practice). If you can't combine it in one filter, maybe try to select the specific monitor via the entity tags  🙂 Excellent question by the way!
