12 Dec 2024 04:44 PM
I was trying to create a policy group to grant a user permissions exclusively for managing synthetics, but I noticed it wasn’t possible this way.
So, I decided to try using Management Zones instead. However, even with this approach, while the user can view the synthetic monitors, they cannot access the configurations or edit the clickpath.
Is there any other way to achieve this?
This is because the requirement specifies that the rest of the platform should remain in read-only mode, and as I mentioned earlier, only synthetic administration should be enabled.
07 Jan 2025 02:50 PM
Hello!
Please take a look at https://community.dynatrace.com/t5/Synthetic-Monitoring/Permissions-for-creating-and-editing-synthet...
