Synthetic Monitoring
Permissions for creating and editing synthetic monitoring
Ilya7
Participant
we would like to give permission for making and editing synthetic monitors to a specific user group for the whole environment.
As far as I'm concerned there is no way to give permission for creating/editing synthetic monitorings without checking "change monitoring settings" for the whole environment or management-zone.
Am I overlooking something? If not will there be a way (i.e. through a schemaId) to give editing permissions for synthetics in the future?
Best regards,
Ilya
9 REPLIES 9
AurelienGravier
DynaMight Champion
DynaMight Champion
Hello @Ilya7 ,
IAM policies is what you need ! You can configure custom IAM through the Dynatrace web UI or REST API :
https://www.dynatrace.com/support/help/shortlink/iam#how-to-configure-iam
Some examples of IAM policies here :
https://www.dynatrace.com/support/help/shortlink/iam-policystatement-syntax
And the list of REST API calls is available here :
https://api.dynatrace.com/spec/#/Policy%20management
Regards Aurélien.
Observability consultant - Dynatrace Associate/Pro/Services certified
Hello @AurelienGravier,
thanks for your response.
I was looking into IAM policies but couldn't find a fitting policy. At first I thought I can go with https://www.dynatrace.com/support/help/shortlink/iam-policystatements#settings-objects-write but the synthetic tab doesn't seem to have a schemaId.
This one might be fitting, I'm not sure though: https://www.dynatrace.com/support/help/shortlink/iam-policystatements#environment-roles-configure-re....
Please let me know if you know the right way of doing this.
Best regards,
Ilya
AurelienGravier
DynaMight Champion
DynaMight Champion
First of all, I have extracted the list of available schemas through the Environment API V2 :
https://{environmentid}.live.dynatrace.com/rest-api-doc/index.jsp#/Settings%20-%20Schemas/getAvailab...
And I select on the response a schemaID related to the synthetic feature:
"schemaId": "builtin:synthetic.browser.name",
"displayName": "Monitor name",
"latestSchemaVersion": "1.0.1"
Afterwards, I use this schemaId as parameter in the following endpoint : /settings/schemas/{schemaId}
https://{environmentid}.live.dynatrace.com/rest-api-doc/index.jsp#/Settings%20-%20Schemas/getSchemaD...
"dynatrace": "1",
"description": "Define the display name of your browser monitor",
"documentation": "",
"schemaGroups": [
"group:synthetic.browser"
And a schemaGroups exists "group:synthetic.browser" on the response.
So I suppose that you can use it in your custom IAM :
ALLOW settings:objects:read, settings:objects:write, settings:schemas:read WHERE settings:schemaGroups = "group:synthetic.browser"
Let me know if it works.
AurelienGravier
DynaMight Champion
DynaMight Champion
Hello @Ilya7
The synthetic monitors configuration is only partially migrated to settings 2.0, so the permissions regarding creation of the monitors (browser and HTTP) are still not available.  I have created the following RFE : https://community.dynatrace.com/t5/Dynatrace-product-ideas/IAM-policy-gt-the-settings-schemaId-relat... I suggest you voting on it to help.
Instead, I have found the way to give permissions on existing synthetic monitors and on settings related to synthetic monitoring :
1st, create your custom policy with the statements below  :
ALLOW settings:objects:read, settings:objects:write, settings:schemas:read WHERE settings:schemaId IN ("builtin:synthetic.browser.name","builtin:synthetic.browser.scheduling","builtin:synthetic.http.name","builtin:synthetic.synthetic-availability-settings","builtin:synthetic.synthetic-availability-settings","builtin:synthetic.browser.outage-handling","builtin:synthetic.http.scheduling","builtin:synthetic.browser.assigned-applications","builtin:synthetic.http.performance-thresholds","builtin:synthetic.browser.kpms","builtin:synthetic.http.assigned-applications","builtin:synthetic.http.outage-handling","builtin:synthetic.http.cookies","builtin:synthetic.browser.performance-thresholds");
2nd, create a new group and bind it the previous policy :
3rd add a use as member of this group.
The user will have the rights to edit each monitors and a limited acces on settings menu :
Regards Aurélien.
Hello Aurélien,
thanks for your effort!
It's really unfortunate that we can't set permissions to create synthetics. With the current options we can't even allow to edit the recorded clickpath for existing browser monitors.
Thanks for creating the RFE. It's a really important feature in my opinion.
Best regards,
Ilya
dan_m_smith
Helper
Hi @AurelienGravier .  Thanks for your help.  When I try to add this to my Policy:
WHERE settings:schemaGroups = "group:synthetic.browser";
I get an error when trying to save:
Policy saving failed
Invalid condition name for permission settings:objects:read : settings:schemaGroups Invalid condition name for permission settings:objects:write : settings:schemaGroups Invalid condition name for permission settings:schemas:read : settings:schemaGroups
Hi @dan_m_smith,
Please use the following statement instead:
ALLOW settings:objects:read, settings:objects:write, settings:schemas:read WHERE settings:schemaGroup = "group:synthetic.browser";
The condition supported is settings:schemaGroup (without "s" at the end).
https://docs.dynatrace.com/docs/manage/identity-access-management/permission-management/manage-user-...
Thanks.
Best Regards
P.A.
dan_m_smith
Helper
I tried to post this once, but here it is again:
I added this to my POlicy:
But I get an error:
Hi @dan_m_smith,
Thanks.
Best Regards
P.A.
