17 Oct 2024
		08:52 AM
		18 Oct 2024
		07:32 AM
Hello all,
is it possible to record Syntethic monitors in fixed timeframe from Monday to Friday from 5:00AM to 10:00AM
17 Oct 2024 08:59 AM
You can use Maintenance windows to stop monitors executing during certain periods of the day. When creating the maintenance window enable the disable Synthetic Monitor execution slider. Alternatively, you can use the Synthetic Monitors API to enable and disable the monitor.
17 Oct 2024 09:03 AM
Thank you Hannah, you are the best! 😉
