06 Apr 2022 05:58 AM - last edited on 06 Apr 2022 08:37 AM by MaciejNeumann
Is there any API call to get the latest availability of a particular synthetic ?
06 Apr 2022 07:55 AM
Hey Pranav1,
You're in luck! There is an API call you can make for that and its documented here.
https://www.dynatrace.com/support/help/dynatrace-api/environment-api/synthetic-v2/synthetic-monitor-...
06 Apr 2022 01:13 PM
And you can also use the metrics available for it, then query with Metrics API - GET metric data point
06 Apr 2022 02:21 PM
I use these extensively. Works flawlessly.
