17 Mar 2020
08:45 AM
13 Apr 2021
02:35 PM
Has anybody came across this situation? I have redirected the active gate to another environment and this what it is showing after configuring the synthetic monitor (Browser).
17 Mar 2020 10:07 AM
On the private location, there are two components installed: Active Gate and the Synthetic engine. Both are needed to execute HTTP and Browser monitors.
The message means the Engine's process is not alive. It is guarded by a watchdog and should be always up and running.
Please create a support ticket for that.
17 Mar 2020 03:53 PM
Well. Disabling the "Dynatrace Remote Plugin Module" worked for me. I think, I started it without knowing the consequence.
Thanks....
17 Mar 2020 06:10 PM
On windows, the engine's service name is in fact "Dynatrace Synthetic" - the one below "Dynatrace Remote Plugin Module".
It must have been stopped at the time the message "Synthetic Engine assigned to location XYZ is offline. Verify its configuration" was being displayed.
I've never heard that those two can't come together so perhaps disabling the plugin service triggered some action on the engine's service. We could make it clear after a detailed investigation.
Tomek
