Synthetic HTTP Monitor domain credential popup.
roy_carroll
Visitor
I have a internal URL that I am trying to setup a Synthetic HTTP Monitor for. The URL is on a separate domain and there is no trust, so I need to be able to supply the domain credentials to access the site when prompted. I tried adding credentials using the set authentication/authorization option with no luck. Confirmed able to browse to the location and supply the credentials in the dialog prompt. Is there a way to pass the necessary domain credentials for the HTTP Monitor? Or a better way to accomplish this?
Philipp_Kastner
Dynatrace Champion
Dynatrace Champion
Hi Roy,
do you know the type of authentication that is used here? If not, you can try to use a browser monitor and provided the credentials via the basic authentication option. (this should also solve NTLM, Kerberos challenges)
Kind regards, Philipp
It's using NTLM authentication. I was able to get it working using a browser monitor setup using our internal gateway which at first I wasn't able to locate, but later I was.
Roy
