Synthetic - Your Connection isn't private bypass
ct_27
DynaMight Champion
DynaMight Champion
When testing some internal sites and running them from private Synthetic AGs I need to handle the untrusted certs.
I did select "Accept any SSL certificate" in the HTTP monitors settings.
Any ideas on how to get around this?
HigherEd
techean
Inactive
Hi, just download that certificate and install it on the system where the browser is open. This will make the system to trust the cert and move ahead without this warning.
check out these links found on google
Fix SSL Certificate Error in Google Chrome [SOLVED] - TechCult
How do I disable the warning Chrome gives if a security certificate is not trusted? - Super User
KG
