Troubleshooting
bhaveshbjoshi
Dynatrace Guide
Dynatrace Guide
Abstract
Infrastructure monitoring of AWS services in different regions using Dynatrace ActiveGates.
Problem
How can a single AWS account be configured to use two ActiveGates to monitor separate regions?
For example, there is a single AWS account, and different regions need to be monitored independently. In this example, there is a need to have one ActiveGate monitor the ap-south-1 region and another ActiveGate monitor the ap-south-2 region. The ActiveGates in this example are referred to as DC AG and DR AG, respectively.
The DC AG should monitor the ap-south-1 region, while the DR AG should monitor the ap-south-2 region.
Resolution
In order to achieve the need in the example, two monitoring configurations must be created for the AWS account with different monitoring roles so that only the desired ActiveGate can monitor a specific configuration. The region to be monitored by each ActiveGates should be set in the custom.properties file:
Example:
Monitoring Configuration for ActiveGate 1 (DC AG)
  • name: <accountName>-ap-south-1
  • role: Dynatrace_monitoring_role_ap-south-1 (DC AG can assume, but not other ActiveGates)
  • DC AG custom properties:
[aws_monitoring]
aws_monitoring_enabled = true
aws_client_regions = ap-south-1
Monitoring Configuration for ActiveGate 1 (DR AG)
  • name: <accountName>-ap-south-2
  • role: Dynatrace_monitoring_role_ap-south-2 (DR AG can assume, not others)
  • DR AG custom.properties:
[aws_monitoring]
aws_client_regions = ap-south-2
Once the above configuration is done, restart the ActiveGate service, dynatracegateway, on both ActiveGates.
systemctl restart dynatracegateway
After restarting, wait for a few minutes and check the Dynatrace AWS monitoring page. As an end result, you should be able to see DC AG monitoring ap-south-1 and DR AG monitoring ap-south-2 region.
What's next
If this article did not help, please open a support ticket, mention that this article was used and provide the following in the ticket:
1. Link to the AWS Account being monitored
  2. Dynatrace monitoring role name
  3. Logs from the ActiveGate
Version history
Last update:
‎02 Apr 2025 04:39 PM
Updated by:
Comments
tarjei
Organizer
Hi!
Why isnt the aws_client_regions documented in the ActiveGate documentation?
bhaveshbjoshi
Dynatrace Guide
Dynatrace Guide
Hi, aws_client_regions is a workaround and I don't see any plans to make it official yet. By default, AWS Monitoring auto-discovers regions to monitor.
Adiawal
Visitor
Hi @bhaveshbjoshi
Why do we need two different monitoring roles?
bhaveshbjoshi
Dynatrace Guide
Dynatrace Guide
hi @Adiawal customer had a specific requirement.
