Troubleshooting
karolinaboba
Dynatrace Advisor
Dynatrace Advisor
An error might occur when attaching a role to an EC2 instance. In such cases, you can use curl to retrieve the instance metadata to verify if the role is listed there. Use the following command:
curl http://169.254.169.254/latest/meta-data/iam/info
If the attached role is still not listed in the instance metadata, it often helps to reattach it.
For more information, see Instance Metadata and User Data.
Version history
Last update:
‎19 Dec 2023 08:37 AM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Thanks for Sharing this @karolinaboba !
