20 Mar 2023 02:50 PM - edited 20 Mar 2023 02:51 PM
These will help describe Dynatrace entities and their status, also can help gather the Dynakube Custom Resource if the location of the yaml used to apply it isn't known. Also including some basic exec commands to get into pods
kubectl get all -n dynatrace kubectl describe all -n dynatrace kubectl get events -n dynatrace --sort-by=.metadata.creationTimestamp kubectl describe nodes kubectl get dynakube -n dynatrace -o yaml
kubectl logs frontend-79db8fc578-48qxh -c install-oneagentoc get all -n dynatrace oc describe all -n dynatrace oc get events -n dynatrace --sort-by=.metadata.creationTimestamp oc describe nodes oc get dynakube -n dynatrace -o yaml
kubectl get all -n dynatrace kubectl describe all -n dynatrace kubectl get events -n dynatrace --sort-by=.metadata.creationTimestamp kubectl logs -n dynatrace nameofdynatracepods (this is good for oneagent pods and csi pods) kubectl describe nodes kubectl get dynakube -n dynatrace -o yaml
kubectl logs oneagent-pod kubectl exec oneagentPodname -n dynatrace -it – sh kubectl exec oneagentPodname -n dynatrace -it –- /bin/bash chroot /mnt/host_root /bin/bash
These labels are subject to change and this information might not be the most up to date source for this.
Quick rundown of how the Webhook pod does the container injections while we have the Dynatrace Operator running in CloudNativeFullStack:
The install of the webhook should lead to all namespaces (with dynatrace operator deployed NS along with anything kube- or openshift- starting) to be applied with the label:dynakube.internal.dynatrace.com/instance
As long as that label is on the namespace that the app pods are starting in, check it with kubectl describe appNamespace , then you should be seeing pod injections on that kind of container.
You can see if a pod was seen by the webhook for injection or not consideration by checking its logs with these two steps:
Gather pod UID for next command:kubectl get pods -n <namespace> <pod-name> -o jsonpath='{.metadata.uid}'
Use Pod UID to search all webhook pod logs:kubectl logs <webhook pod name> -n dynatrace | grep <UID of the pod that was launched>
And Further validation on if a pod was injected into by the webhook or not can be seen by inspecting the pods labels for the label: dynakube.dynatrace.com/injectedkubectl describe pod podName -n PodNamespace | grep dynakube.dynatrace.com/injected
Also.. if you're working on cloudNative issues and wondering where the application/pod logs are.. they're located on the instrumented/injected application pods, you can find the log locations if you exec in and run something like the below:
sudo ls -lash /proc/*/fd | grep oneagent
Copying logs out of container
If tar binary is on the app pod you can use kubectl cpkubectl cp namespace/podname:/opt/dynatrace/oneagent-paas/log /tmp/logsIf tar is unavailable on the app pod you can try something like the below:kubectl exec <pod-name> – find <directory-path> -type f | xargs -I {} sh -c 'kubectl exec <pod-name> – cat {} > <local-path>/${1#<directory-path>}' _ {}
orkubectl exec myapp-123 – find /data/logs -type f | xargs -I {} sh -c 'kubectl exec myapp-123 – cat {} > /tmp/${1#/data/logs}' _ {}
Thank you for sharing this! I'm sure it will help out many community members.
