Troubleshooting
darynakovyrina
Dynatrace Mentor
Dynatrace Mentor
Example error on the ActiveGate deployment status page:
Problem with ActiveGate token (reason:Absent)
Example error on Dynatrace Operator logs:
{"level":"info","ts":"2022-09-22T06:49:17.351Z","logger":"dynakube-controller","msg":"reconciling DynaKube","namespace":"dynatrace","name":"dynakube"}
{"level":"info","ts":"2022-09-22T06:49:17.502Z","logger":"dynakube-controller","msg":"problem with token detected","dynakube":"dynakube","token":"APIToken","msg":"Token on secret dynatrace:dynakube missing scopes [activeGateTokenManagement.create]"}
Example error on DynaKube status:
status:
    conditions:
    - message: Token on secret dynatrace:dynakube missing scopes [activeGateTokenManagement.create]
      reason: TokenScopeMissing
      status: "False"
      type: APIToken
Starting with Dynatrace Operator version 0.9.0, Dynatrace Operator handles the ActiveGate token by default. If you're getting one of these errors, follow the instructions below, according to your Dynatrace Operator version.
  • For Dynatrace Operator versions earlier than 0.7.0: you need to upgrade to the latest Dynatrace Operator version.
  • For Dynatrace Operator version 0.7.0 or later, but earlier than version 0.9.0: you need to create a new access token. For instructions, see Tokens and permissions required: Dynatrace Operator token.
Version history
Last update:
‎19 Dec 2023 03:21 PM
Updated by:
Comments
ChadTurner
DynaMight Legend
DynaMight Legend
Thank you for Sharing this @darynakovyrina !
